Max:
HP: 136 (red line)
Torque: 147 (blue line)
Boost: 10.7 (yellow line)
It was my understanding that a stock turbo legacy was 160 hp / 181 ft lbs torque. Sure, I realize there is some loss due to the drivetrain, etc. So that being the case, the 160 hp number is at the crank? How would I then go about calculating how much of an improvement over stock my current setup is?
Anyways, I plan on getting it dynoed again once I've got a VF39 and 06 TMIC installed in a few months. I'm curious to see the raw numbers of the increase. Anyone else have their upgrade performance documented with dyno runs?
