Parts
metalhead77
Parts
Interchangeable or similar parts between Legacy's and Impreza's from all years. Can you guys give me a short list of these parts. I'm mainly concerned with engine, suspension/steering, and brake parts. Thanks.
Everything you just listed.
The '93-01 Impreza was based on the original Legacy platform. So with minor exeptions, it all works.
The electrical systems changed alot through the years however.
metalhead77
- quasi-mod-o
There is no blanket statement that all parts from any one Subaru will fit any other Subaru.
Yes, a lot of stuff is interchangeable... more than just about any other make I'd say.
But there are still anomalies, and just buying parts from an Impreza with a natural assumption that they'll fit just because they're based on the same platform is not a good idea.
What specifically are you trying to interchange?
metalhead77
I'm not sure what exact piece it is, but a part of my front suspension/steering makes a terrible grinding noise at low speed/rev. I think its one of the CV shafts (I believe that's what they're called) but I don't know for sure. I'm also asking in reference to aftermarket parts. I know most Subaru engines are pretty similar, the only difference being cylinder size/number. And I wasn't assuming a blanket statement that ALL parts from one Subaru work on another. I know they won't. But I'm asking if the parts are interchangeable with little to no modification/fabrication. That's all I'm concerned with.
metalhead77
