Idea for clutch reservoir
Front, Top, Air, Water.
GeneralDisorder
Post by GeneralDisorder »
I was working on a Ford Contour for a friend and when I went to fill the clutch reservoir I was a bit confused.... I simply couldn't find it.
I looked in my Haynes manual which covers all but the last year of the Contour and it said it was under the dash..... Not!
After not finding it anywhere I decided to follow the plumbing from the MC.... turns out on the last year of the contour they just got rid of the reservoir and ran a hose to the Brake MC reservoir. What a cool idea!
Why not cut down the existing reservoir and put a nipple on it for a hose to the Brake reservoir?
GD
91 SS, 94 GT, 84 Wagon, 83 Hatch, 85 Brat.
That's not a bad idea if it's done right.
Dr. Gonzo
Post by Dr. Gonzo »
Hmmm, or another idea thats probably way more difficult: My car was swapped from an auto to a manual and a cable type clutch went in instead of the hydraulic style clutch. I didn't even think of this till last night when I laid in my 06 intecooler, low and behold it fits great :-)
04 Forester XTi VF39, TMIC, 3" exhaust, COBB accessport
92 Legacy L wagon 5 spd, 266K miles
83 wagon SOLD
04 STi COBB stage 2 & wingless SOLD
92 Legacy SS 5MT-TD04,TMIC, 3"exhaust SOLD
00 Legacy GT wagon 5spd SOLD
90 Legacy LSi wagon
GeneralDisorder
Dr. Gonzo wrote:Hmmm, or another idea thats probably way more difficult: My car was swapped from an auto to a manual and a cable type clutch went in instead of the hydraulic style clutch. I didn't even think of this till last night when I laid in my 06 intecooler, low and behold it fits great :-)
That works if you plan on using NA transmissions. True turbo transmissions are not setup for cable clutches are they entirely different.
GD
greg donovan
Post by greg donovan »
i wonder if it would be possible to fit the countour clutch MC onto a subaru?
might need to make a couple adapters but i would imagine it could work.
wouldnt be any different than istalling a race setup like a tilton cluch pedal and MC.
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
MannyMohawk#5
Post by MannyMohawk#5 »
My friend actually got a clutch reservoir off a 92ish Eclipse at a junkyard that had an offset to it, and we trimmed an inch off and it fit/worked great. But the idea of plumbing it from the brake reservoir is pretty cool.
93 SS 5-speed
93 Touring Wagon ej20g
GeneralDisorder
I'll have a look at my buddy's 91 eclipse and check out that reservoir on there. Thanks for the tip.
GD
