Serious coolant leak
Spitfire999
Post by Spitfire999 »
So, I arrive home last night, throw my car in park. I notice it was smoking a bit from the engine bay (It does have a small oil leak, at least I assume, that spits a bit of oil onto the exhaust or something and smokes), I assumed it was normal.
I noticed it was a bit more smoke than normal, pop the hood, seems smokey. Hmmm...then I look on the ground...liquid...uhoh....Look under the car, to see coolant coming all around the back of the engine...s**t.
So, my dad jacked it up while I was at work today, he said he couldn't see where it was coming from, somewhere nearer the back on the turbo side. He said the up-pipe was in the way of seeing exactly where it was from. He said he topped it up with some water, and ran it up to temperature, the leaking seemed to stop.
At first, my immediate thought was HG blow (assumed the worst). But I have noticed no difference in the engine power/how it runs. It also seemed like a lot of coolant for it to be a head gasket. The oil also seemed to be coolant free.
So now I'm thinking back to the bit of smoke that would appear in that area previously, and I'm thinking it may have been coolant causing that -> indicating a small leak -> meaning it could have just turned into a big leak.
Basically, anyone have any idea what it might be. Apart from a HG being the worst case scenario, I was possibly thinking coolant line for the turbo (hopefully). Anything else that it could possibly be?
Ben
BSOD2600
Post by BSOD2600 »
I had the coolant line which ran on the turbo side of the engine, spring a leak last year. Was sort of hard to see, but once the intake stuff was moved out of the way, it was obvious where the leak was. It was the tube which is U-shaped. Just a thought...
'11 WRX Limited
'94 TW | R.I.P.
Spitfire999
I found the leak...its a tube that runs from the throttle body to the intake mani. About 2 inches long or so (not sure if you are talking about the same one BSOD2600). I thought it was a lot of coolant leaking from that small hose, then I discovered the cap on my coolant tank had a rubber gasket disintegrate and that was leaking...
I'm back on track now guys. Sorry for freaking out :-D
Ben
