random 91 ss and Imp parts
adema2626
Post by adema2626 »
This is all used parts.
2 early 80's Subaru wheels $25
Legacy SS:
91 Intake manifold $10
91 rear lateral links? So you can have a RSB $5
91 RSB missing bushings $5
91 hydro tranny case. No internals $10
Charge pipe no cracks $5 SOLD!
Brand new!
EJ22T timing belt (Brand Gator) $5
Impreza:
95 Starter for a 5 speed $10
Starter (1996-93) Subaru Impreza 1.8L w/ MT (1996) Subaru Impreza 2.2L w/ MT $10
Everything you need for a Sub/amp. $10 SOLD!
95 AWD xmember SOLD!
95 4.11 open rear diff with axles SOLD!
EJ18 heads $20 for both SOLD!
Four 13" steelies $10
93-95 Hood with hole for hood scoop. Centered $10
Water pump unknown miles but looks brand new and spins freely $5
99% sure that I have everything you need for AC and since I'm not 100% sure all sell it for $25. Everything was functioning when pulled.
Splash guards $5
2.5RS suspention(unknown miles) $20
Just want this stuff out of my storage space. Prices do not include shipping, thanks!
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
adema2626
Post by adema2626 »
bump
adema2626
Post by adema2626 »
bumpity
atroby91
Post by atroby91 »
what color is the shift boot?
Any chance you would have the throttle body for your original impreza motor?
From what I have seen the throttle cam for the cruise is slightly smaller on the models with cruise from the factory.
ThreeEyedBandit
Post by ThreeEyedBandit »
How much to get the clutch master and slave cylinder to 97501?
Matt
adema2626
Post by adema2626 »
Legacy777 wrote:Any chance you would have the throttle body for your original impreza motor?
I do have the throttle body but i don't wanna part out the motor since its whole minus the engine harness. Sorry.
adema2626
Post by adema2626 »
ThreeEyedBandit wrote:How much to get the clutch master and slave cylinder to 97501?
Matt
sent you a pm!
adema2626
Post by adema2626 »
slave/master sold!
Oh i also have a brand new gator timing belt for a 91 legacy SS
Any chance you could take a picture of the throttle body & cables/cams for me?
Thanks!
adema2626
Post by adema2626 »
bummp
I also have some 91 rear lateral links and a 91 RSB
adema2626
Post by adema2626 »
bumpp
adema2626
Post by adema2626 »
buuuuuuumpity
sublunacy
Post by sublunacy »
Free Bump.
He has the rear 'Control arms" With the sway bar links, and a sway bar + mounts
Everything you need to put a rear sway bar on your N/A Legacy.....
A new Timing Belt too.....
"Hows the transition look?"
91 turbo manual
BMX in the trunk!!!
adema2626
Post by adema2626 »
buuump
Also have everything you need to put AC in your car. The only thing i cant seem to find is the piece that goes under the dash. This is out of a 95 Subaru Impreza
TdotSubie
Post by TdotSubie »
Would the lateral links fit a 94 impreza? Also, do you know what size the sway bar is?
adema2626
Post by adema2626 »
Yes they would fit on a 94 impreza, they were on my 93 imp and 95 imp at one point. The only thing you would need to get are the brackets to mount the sway bar on at a junk yard. Have your gf go with you and put them in her purse haha that's how i got mine. Just make sure its a purse she doesn't like... But the only thing with them is that 91 had a special type of set up so you cant upgrade to beefy endlinks(i think whiteline does maybe make better ones, correct me if im wrong guys). The sway bar is also 17mm i believe? I'm pretty sure that's what iv heard maybe one of the legacy guys will chime in.
adema2626
Post by adema2626 »
Bummmp anyone want this stuff? Added a few things and deleted some.
Arturo
reply
Post by Arturo »
what color is the trim that goes around the shift boot i am looking for one
Suby tech on the way
xbn377
Post by xbn377 »
Timing belt to 49660?
Shawn
91 Legacy SS AT
93 Legacy L Wagon
To get your hands on superior lubricant products from AMSOIL utilize the following url:
http://www.amsoil.com/redirect.cgi?zo=1819626&page=store
adema2626
Re: random 91 ss and Imp parts
Post by adema2626 »
Buuuuuuuuuump
91legacyawdturbo
Post by 91legacyawdturbo »
hydro trany case is that the whole transmission case?? if so would you be willing to ship and any pics???
2002 wrx sport wagon
adema2626
Post by adema2626 »
You will be everything, but the internal goodies which are scrap. I would rather not ship it though just due to it's size. I might possibly if the price was right.
This is what happens when your car is RWD and your playing around the tranny gets low on oil.
Everything is still in the tranny as you can see. If you would like more specific pictures I can make that happen.
adema2626
Post by adema2626 »
Bump
adema2626
Post by adema2626 »
Bummmmp.
