We built these heads for our new website pictures, now just ready to ship out.
Std. valves, three angle cut, surfaced, pressure checked, this set of heads does not come with cams, however, If you want the modified cams I will give you 25% off the cost of cam grinds and will need to do your cores.
Ken @ Delta Cam
