for those of you running a 06/07 newer style intercooler...
can you guys please tell me which year model silicone y pipe you used...will a 02- 05 work, or does it need to be an 06-07?
i tried using the stock y pipe but even if i could it would be super restrictive putting a piece of pipe inside it.
i hear reading helps
i dont really like it, and i am also running a td04, but anyways can i use a 02 to 05 y pipe or does it need to be 06/07 specific?
dscoobydoo
i do have an older style one to with aluminum aps y pipe, it would line up with a simple silicone 90 but i bought the 06 to use it. if anyone is interested, the 04 ic and aps y pipe w/gaskets, 2 sets, is for sale for 100$
why did you edit this, didn't it use to say "i hear subarunation has a good right up on this"????SubaruNation wrote:i hear reading helps
sorry, i had to edit this because i wanted to ask how your dryer hose worked out as a y pipe???
making an example of my mistrust of others recommendations, is a poor way to put me down for something you clearly have no prior knowledge of.
nobody is starting beef with you, and on here we treat each other with respect.
maybe you have read the forum rules,
they are right here just in case: http://bbs.legacycentral.org/viewtopic.php?t=34486
glad we could clear up any misunderstanding.
it's no misunderstanding, i was just stating my opinion, which i am allowed to do, i'm not lookin for beef or trying to start it so we shouldn't start any, no big deal.
