gen 2 MT into gen 1 car - any difference electrically?
Bosco
Post by Bosco »
Well, I think I'd better ask before I start clipping wires.
I'm swapping a '97 LGT Trans Into a '94 Touring Wagon.
As far as the electrical stuff goes, can I Simply follow Josh's 5mt swap write-up as it is, or do I need to do something differently?
I figure there is likely to be a wiring difference somewhere, and I don't want to find out after I've messed it up already.
Thanks for any help.
94 Legacy Touring Wagon - 5MT Swapped and now with 100% less turbo!
02 Legacy L wagon - Auto
92 Legacy L fwd auto
It should be the same. The only difference will be you will need to pull the electronic speed sensor out, and put the manual speedo gear/cable in.
Bosco
Post by Bosco »
Legacy777 wrote:It should be the same. The only difference will be you will need to pull the electronic speed sensor out, and put the manual speedo gear/cable in.
Okay great. Thankya.
so , by "manual speedo gear/cable" do you mean a speedometer cable from a 5mt car and the "recepticle" on the transmission it clips in to?
can I use the one from the auto transmission, or does the "recepticle" have to be from a 5mt too? (I probably should be beaten with the search stick for that one)
I assume I need a 5mt cruise computer from a 1st gen car, or can I actually use the one in the 97?
You can use the "recepticle" from an old 5MT. The auto one will be too short.
I doubt the cruise computer connections are the same from 1st to 2nd gen. A 1st gen computer is easy to set up.
Don't repeat my "experiment" with the speedo cable.
http://bbs.legacycentral.org/viewtopic. ... ght=speedo
