ej25 or ej22 in a ej18 impreza
the_watts10
Post by the_watts10 »
so from what ive gathered from looking around in the engine index is that i can put a ej25 or a ej22 into my 1994 ej18 impreza without the computer noticing is this correct or not
ej22t hybrid, 3.5" downpipe, Gl turbo intake/desnorkel 9psi DEAD
the_watts10
any suggestions
Aussie_in_mo
Post by Aussie_in_mo »
EJ22... Gets away from the HG issues on the EJ25.
'82 Brat (EA81 w/73hp and a 4spd single range trans)
'00 OBW (EJ25 w/5spd)
BXSS
Post by BXSS »
+1
ej22 = 300,000 miles no problems
ej25 = h/g's every few miles
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
Definitely EJ22. I'll be using one in my Cessna car and would consider nothing else unless cost was no object (then I'd probably make it an electric). One big reason I didn't buy a new Subaru was that the no longer sell the 2.2 (because the cars are too f'n heavy to be moved by them, which is a combination, a Siamese if you will, issue that I had).
