poor low rpm performance
I have a 92 EJ22 in my 85 wagon. It ran fine after the swap for about a year then it started running weak at low rpm. Under about 2500 rpm it barely accelerates, then when it passes a certain rpm (about 2500 my tach isn't hooked up) the engine kicks in and runs normal. This behavior is independent of throttle setting, engine temperature or vehicle speed. I've replaced the thermostat, maf sensor, O2 sensor and checked the tps(it's ok). It's runs rich at low rpm evidently. It started a couple months before my emissions test. It fouled out plugs and wiped out the O2 sensor (all were covered with black soot. It was running way rich at both low and high rpm. When I replaced the O2 sensor the high rpm passed but the low rpm was still rich-about 3 times the maximum allowable HC and CO limits. The new cat brought low speed emissions into compliance also but if I keep running it I'll wipe out the O2 sensor and the cat again. The computer isn't setting any codes. I'm stumped - any ideas?
Sounds like its running like crap on closed loop & ok on open loop (? the exact rpm# for your particular motor - my OBDII PII 2.2 does open loop @ 3700RPMS).
Based on what you wrote you covered almost all the bases, but you did not change the coolant temp sensor & if it is bad it can cause crazy afr's...
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
I know you said it ran fine for a year but check this thread out -
http://bbs.legacycentral.org/viewtopic.php?t=35236
Essentially the intake cancels out some pulses that prevent the MAF from getting confused at low rpm.
