seatbelt light stays on
machgirl
Post by machgirl »
Hey all. My 93 legacy wagon's seatbelt light stays on blinking constantly....I was told it was a bad automatic seatbelt assembly?
n2x4
Post by n2x4 »
Check the plug under the drivers seat. It should have a connector in it that runs up to the seat belt. That may be cut/disconnected. You can try connecting those two wires together and see if that turns off the light.
SUBARUEHS Racing
machgirl
Post by machgirl »
n2x4 wrote:Check the plug under the drivers seat. It should have a connector in it that runs up to the seat belt. That may be cut/disconnected. You can try connecting those two wires together and see if that turns off the light.
That connector is good, I already tried that...
machgirl
Post by machgirl »
Ok, will see what I can find, thanks.
