I've just removed 29 pounds of AC system from my engine bay since it's R-12 and I don't care to convert. A little extra fuel economy and performance is nice too.
I've removed all the mechanical stuff under the hood, and haven't touched the evaporator core or anything else inside, or electrical.
I don't plan on touching the evaporator core (unless you think it's easy), but I wanted to know what else I can remove. I'm particularly interested in what fuses and relays I can remove without interrupting anything else (I don't want to, for example, accidentally disable the radiator fans altogether). Will removing the two AC fuses and four AC relays in the engine compartment fuse box has any adverse effects?
