EDIT: Purchased one from subieal, thanks!
Because I may very well be an idiot, I think I've fried the circuit for my canister purge solenoid (link) resulting in a permanent check engine light, poor idle, and poor economy. One little transistor, and the show's over.
I need an ECU (ECM, PCM, what ever else you may call the engine computer) for my 1992 Legacy L Sedan AWD N/A 5MT, if any more information is needed let me know.
Thanks.
WTB: ECU for my '92 Legacy
Soul Shinobi
-Nick
1992 BC Legacy L Sedan AWD 5MT 272,000 - Wish you the best
1998 BK Legacy L Wagon 5MT 234,000 miles - RIP
2002 SF Forester S Wagon 5MT 215,000 miles - Current winter sleigh
1986 FC Mazda RX-7 GXL Coupe 5MT 155,000 miles - Summer cruiser
could it possibly be your O2 sensor? because when my o2 wasn't getting enough flow and alot of back up from the cat that i was infront of it threw the o2, and the purge solenoid code.
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
Soul Shinobi
After tripping the Coolant Temperature Sensor to test my Main Fan Relay I had four DTCs (Diagnostic Trouble Codes).
13 Cam Angle Sensor
21 Coolant Temperature Sensor
32 Oxygen (O2) Sensor
35 Canister Purge Solenoid
I cleared the codes, and only code 35 for the solenoid remained. I've thrown the Cam and O2 codes before with no apparent cause, so I don't think they meant anything here either (they're gone now anyway).
I just double checked the codes, since I've driven it a couple times since I last checked it. Just code 35.
13 Cam Angle Sensor
-Nick
Arctic Assassian
Soul Shinobi
Holy crap, Arctic, I didn't realize how good this site was. I'll definitely call around using this database, thank you.
-Nick
Arctic Assassian
gotsubarus
Soul Shinobi
Oh, I forgot to mention that a member sold me one, but if it doesn't work out I'll let you know.
-Nick
