WTB: ECU for my '92 Legacy
Posted: Sat Oct 25, 2008 6:02 pm
by Soul Shinobi
EDIT: Purchased one from subieal, thanks!
Because I may very well be an idiot, I think I've fried the circuit for my canister purge solenoid (
link) resulting in a permanent check engine light, poor idle, and poor economy. One little transistor, and the show's over.
I need an ECU (ECM, PCM, what ever else you may call the engine computer) for my 1992 Legacy L Sedan AWD N/A 5MT, if any more information is needed let me know.
Thanks.
Posted: Sun Oct 26, 2008 1:08 am
by adema2626
could it possibly be your O2 sensor? because when my o2 wasn't getting enough flow and alot of back up from the cat that i was infront of it threw the o2, and the purge solenoid code.
Posted: Sun Oct 26, 2008 5:51 am
by Soul Shinobi
After tripping the Coolant Temperature Sensor to test my Main Fan Relay I had four DTCs (Diagnostic Trouble Codes).
13 Cam Angle Sensor
21 Coolant Temperature Sensor
32 Oxygen (O2) Sensor
35 Canister Purge Solenoid
I cleared the codes, and only code 35 for the solenoid remained. I've thrown the Cam and O2 codes before with no apparent cause, so I don't think they meant anything here either (they're gone now anyway).
I just double checked the codes, since I've driven it a couple times since I last checked it. Just code 35.
Posted: Mon Oct 27, 2008 7:12 pm
by Arctic Assassian
Posted: Mon Oct 27, 2008 9:08 pm
by Soul Shinobi
Holy crap, Arctic, I didn't realize how good this site was. I'll definitely call around using this database, thank you.
Posted: Tue Oct 28, 2008 7:17 pm
by Arctic Assassian
No problem
Posted: Fri Oct 31, 2008 3:01 pm
by gotsubarus
i probably have it... what are the #s on yours
Posted: Fri Oct 31, 2008 3:03 pm
by Soul Shinobi
Oh, I forgot to mention that a member sold me one, but if it doesn't work out I'll let you know.
