is this normal? btw i dont know how to upload a pic
i noticed this the other day up above the ex manifold in the picture
http://www.bebo.com/PhotoAlbumBig.jsp?M ... 9286503347
i was running wastegate boost on my td05h 16g 6psi at manifold with fmic engine doesnt seem to get hot but engine bay seems pretty warm im guessing that is bcos of my lack of heat sheilds and turbo chim
[/img]
is this normal?
Daniel Burgess <pearlescent_panda>: Subaru Legacy GT
You are not authorized to view this Photo Album.
If you want to insert a picture into a thread just right click on the picture on whatever site you have it hosted on and go to properties. Then copy the URL of the picture. Then click the "Img" button when you're posting and paste in the url and then hit the img button again.
Done deal.
that's normal with these cars. They always had cooling problems, unless you got an aluminum radiator and updated the coolant tank.
Now go get a coolant funnel, with the little stopper, and fill your car with coolant while its cold. Then turn the car on and put all of the electrical loads on and wait for the fans to kick on. That means the t-stat has come on. Presto chango! Your cooling system has been bled and everything works fine.
Also, put them heatsheilds back on.
-Adam
-Adam
Kickin' it old-school.
