Narrowest Tire Size that will fit on 7.5 width rims?
Adam West
Post by Adam West »
Would 215's fitted on a 7.5 in wide rim be wacky? What would that look like?
I've read the fit threads and it seems that 7.5 rim-owners are rare with our cars. Why dat? Just because that is a more rare size?
http://bbs.legacycentral.org/viewtopic.php?t=36044
Why I want 7.5 inch wide rims? (17" diameter, 48mm offset)
> I eventually want to run 225+ on the car after coilovers, spacers and fender rolling...BUT I'd like to start with the wheels now.
Thanks in advance for the info/opinion!
AW
asc_up
Post by asc_up »
I think 215's on a 7.5" rim would be fine. I have 235's on a 8" wide rim and it doesn't look bad at all, so you should be fine.
Buffman
Post by Buffman »
my 15x6 skinnies could fit a 185-195 tire. A 7.5 should be easily able to hanlde a 215.
1992 Legacy LS Special Wagon..
I've been putting 205's on 7.5" wheels for a long time. On a 205, 7.5" wheel is at the max of the spec, but you should check the tires specs first. I doubt you are running a 35 series tire though.
SP-Boxer
Post by SP-Boxer »
Not the best picture. This is a 215/45/17 tire on a 7.5" wheel :)
"I feel Legacy"
Apex3
Post by Apex3 »
205/50R16 on a 7.5" wheel
It's got a bit of a stretch, not much though
