Fuel Injec and Axle compat Q
madkow007
Post by madkow007 »
Will the fuel injectors from a 90 leg EJ22 5 speed work in a 91 leg EJ22 auto?
2nd Q
Will the front axles from a 90 leg 5 speed awd work on a 91 leg auto 2wd?
Thanks for any help
1st question, no.
2nd question, yes. The AWD front axles are smaller in diameter, but that shouldn't matter.
1st question clarification. The injectors would work if you swapped fuel rails and really the ECU, since they are different manufacturers, but then you run into other issues like MAF compatibility between the AT & MT cars. So the short answer is no.
madkow007
Post by madkow007 »
thanks for the reply Josh...that was kind of what I thought to
Have been told yes and no.
