Just ANOTHER 1990 Legacy turbo conversion.... hahahahahah
douglas vincent
Post by douglas vincent »
Yep, another one. Replacing the 2.2 NA with an NA 2.5 block, STI crank and rods, 100 mm Mahles, twin turbo heads from the Reddevil that just split the cylinder walls, 550cc injectors, 6 puck and upgraded pressure plate, PP6, yada yada yada
douglas vincent
$190 shipped for 6puck and valeo "upgraded" pressure plate. we shall see.
Fastest drop in ever for me.
Last edited by douglas vincent on Sun Nov 23, 2008 2:12 am, edited 2 times in total.
douglas vincent
December 6th, pulled the front end off to swap over painted hood, bumber and fenders. Ghetto, but on its way.
3:30
4:15
ImageDecember 6th, pulled the front end off to swap over painted hood, bumber and fenders. Ghetto, but on its way.
3:30
4:15
Then after dinner I went back in and installed the pre-painted hood, fenders and bumper.
Last edited by douglas vincent on Sun Dec 07, 2008 10:58 pm, edited 2 times in total.
douglas vincent
Is Satan your Saviour, Or is Bush? Either way, Obama is President!
94SS_Canada
Post by 94SS_Canada »
Your awesome.
look forward to more pics.
FastRust
Kelly
Post by Kelly »
Dont encourage him!
J/K :-D
Kelly wrote:Dont encourage him!
J/K :-D
Hahahaha :)
bmxpunk
Post by bmxpunk »
Why does one always smile when Douglas starts a new thread/build.
2011 Mini Countryman S All4
1970 Honda Ct90
Arctic Assassian
Post by Arctic Assassian »
I don't know what I would do with his kinda time. Probably blow myself up on accident.
Kickin' it old-school.
94SS_Canada
bmxpunk wrote:Why does one always smile when Douglas starts a new thread/build.
Only because he knows what he is doing and is worth while to watch, me on the other hand....
FastRust
94SS_Canada
Arctic Assassian wrote:I don't know what I would do with his kinda time. Probably blow myself up on accident.
Probably put in the wrong block because you couldnt identify the diffrences, then blow yourself up. hahaha, JK!
FastRust
Is that the EJ22T intake? I thought somebody told me you couldn't use it on DOHC heads?
douglas vincent
No, its a phase 2 2.5 NA intake I painted.
douglas vincent
In, pics in post 2!
94SS_Canada
That explains alot, No turbo....?
FastRust
douglas vincent
No turbo for the first couple hundred miles.
Probably going to go with a Subaru turbo and a top mount.
douglas vincent
So close to turning it over tonight. But the lack of 4.5 quarts of oil slowed me down.
douglas vincent
Well... Started it up. Smooth as butter! Backed it up and added water. Sweet!
Then added power steering fluid (ATF) as i had swapped pumps.....
POW! Off shoots the pressurized side. Tighten it up and POW off it shoots again. Well, there is a reason the pressurized side is a single hard line. I had had to cut and modify the pressure side and "hope" my bandaid held. Not a chance. Have to see what I can do to connect the two metal lines. I am going to get a double ended flaring tool and should be able to do a pressure joint.
douglas vincent
$44 later after a visit to Oil Filter Service, my two lines are now one!
Bolted the line back in, filled it with ATF, fired it up and drove up and down the street to set the rings.
Runs excellent! Need to do some fine tuning @ idle, but for NA driving right now its seemingly great!
92ss satinsvoice
Post by 92ss satinsvoice »
right on doug! did you ever get the red sedan goin?
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
Hey I noticed you're using the same block as my twin turbo motor. How did you go about plugging the oil line on the back of the head? It looks like you just left the pipe on and plugged the hose?
Is that what I should do? I've been trying to figure out how to get that off but if it's not necessary to remove it that's good. What did you plug it with?
douglas vincent
Rubber hose with a sparkplug stuck in it! for now.....
Yeah, been driving the sedan for about a month now. but its back in the garage now that the wagon is running again.
Nice! I plugged the oil lines on my N/A'd turbo with a bolt in the hose.
Is that the best way to do it? Not gonna pop out and shoot oil everywhere?
douglas vincent
No, not the best, but works for now. and it won't shoot oil everwhere unless you break a piston, because this is the RETURN so there is no pressure.
