wrx brake swap
90leggy
wrx brake swap
Post by 90leggy »
when i swap the stock brakes on my 1990 legacy out for wrx brakes, should i get a wrx master cylinder and/or brake booster? or will my stock ones do fine with them?
1990 L, 5mt, awd
90leggy
Post by 90leggy »
yeah i should have researched a little first. thats what i get for being lazy ahahah. nevermind.
1990 L, 5mt, awd
dropdfocus
Post by dropdfocus »
You'll be fine with your stock parts when installing the WRX calipers/brackets. Getting yourself a master cylinder brace helps under heavy braking. These typically mount off the side of the strut tower, but I've seen them mount straight down to the unibody frame rail.
Jason
PhyrraM
Post by PhyrraM »
Don't forget wheels if you need them. Stock SS wheels will not clear WRX brakes.
dropdfocus
Yes, another very good factoid to present! Way to catch that... :cool:
Jason
90leggy
Post by 90leggy »
oh yeah i thought wheels were pretty much a given. im looking at a set of wrx wheels some guy has for $300 with pirelli tires on them, just minor curb rash :-)
1990 L, 5mt, awd
Does your 1990 have ABS?
90leggy
Post by 90leggy »
not too sure. im just beginning to work with cars, maybe i should check that out
1990 L, 5mt, awd
