Rear sway bar mount right side
drsevy
Post by drsevy »
the mount behind the rear wheel has rusted and broken off (is justa hangin) anybody have any experience repairing these ? ;-)
95 Legacy L Wagon Silver 5speed 265K miles
95 Legacy L wagon Maroon Auto 135K miles
96 Legacy Outback Wagon Auto 215K miles
67 VW SC Pickup 35K miles
80 VW Diesel Dasher Wagon 212K miles
90 Chevy Z71 4 X 4 91K miles
90 Toyoto Camry 205K miles
Hopefully it's just the mount. If so, you can just buy another one and put it in. There are some heavier duty aftermarket ones if you so choose.
As for replacement. There are two bolts holding it to the chassis. Hopefully the chassis is alright. I'd suggest soaking the bolts in penetrating oil to aid in removal.
Threshld1
Post by Threshld1 »
Ewww i hope its just your mount bracket as well. I just pulled these brackets off my 93 and both the frontmost bolts sheared right off. Good thing the chassis is scrap otherwise i would be extra pissed. Exp. since the right side front bolt is dead middle under the fuel filler. Making it much more of a whore to drill out. Lots of penetrate and work the bolt in and out if you can get it to turn.
Best of luck!
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
