so would 205/70/r15s be able to fit??
THere is a set for dirt cheap onj craigslist and i plan on doing some snowboarding this winter!
So... i doubt my Sunny SN3800 tires will do well in snow
flatoutfred
Well, I dont have spring perches... i cut them off when i put Coilover sleeves on.
Stock wheels? Offset will play a major role.
I tried some Forester wheels and tires on the rear of my SS just for fun (same size as what you're looking for). They just barely touched the rear spring perches. I can try and take a pic to show how close they are. I imagine if you don't have perches, there won't be a problem. I didn't try them on the front of the car though. Raise your car up as high as you can with the coilovers and I bet you'll be ok.
SUBARUEHS Racing
