WTB: 93 legacy non turbo wagon TCU
Exactly what the title says. Specifically I guess anything 92-94 and needs to be a wagon and non turbo. Thanks!
Ya according to what I was told. Supposedly different shifting points, because there is a weight difference. My TCU was replaced when my transmission was rebuilt, but it shifts really crappy. So hoping this resolves that as well as my awd issue.
TCU
i doubt it is the TCU.... I would clean all the grounds and wire connectors at the transmission first. TCU's rarely go bad in these cars. Also you will need a 92-94 TCU for AWD Wagon
bump someone closer to canada ? Looking for something cheap since I am not sure this will do much of anything. Thinking around $30 CDN max. Not sure if that is to low, but I figure it is not that valuable of a item especially you guys swapping to 5mt.
