Alright, I've purchased a 20mm WRX wagon front sway bar for my 91 turbo legacy and now I'd like to buy a 20mm rear sway bar and I found out that whiteline sells it.
Part number BSR17X
Question is, where can I buy one at? Not from whiteline either. They want $152 for shipping which comes out to $381
That's too much. I searched google for the part number and found an old post on ultimate subaru message board from a dealer in the US that was selling them for $145.
OK well I guess I didn't think to check their vendors and found out Global Performance parts carries whiteline products and I checked their website and it says it's in stock for $193 plus like $17 for shipping. Which is way better. That's the the 20mm adjustable swaybar.
Do I need an adjustable sway bar? Probably not. Would I really want to adjust it down to 18mm again?
Now I'm really confused. I searched for BSR17XZ and it comes up with a 20mm rear sway bar for $245 but if I search for BSR19XZ it comes up with the same thing for $193.
Something is not right here.
kimokalihi wrote:Now I'm really confused. I searched for BSR17XZ and it comes up with a 20mm rear sway bar for $245 but if I search for BSR19XZ it comes up with the same thing for $193.
It's the same bar, but BSR17XZ comes with special endlinks that work with the 91 lateral link. The 92-94 have a different lateral link and you can re-use the stock endlinks, so the BSR19XZ does not include anything but the bar and bushings.
-steve-
03 Legacy L Wagon
91 Legacy Sport Sedan - SOLD
Alright, thanks. So I need the BSR17XZ bar then for my 91?
Does it come with new bushings for everything or do I have to reuse 170K mile bushings?
Whiteline kits usually come with bushings, as the bar is usually a different diameter than the stock bar. That's the point, right? Someone had a set of those 91 style drop links for sale, email me...
-steve-
03 Legacy L Wagon
It's 22mm but you can just leave it at full soft. I can call a few places tomorrow to find out our price on it if you'd like.
It does come with urethane bushings. It may not be a bad idea to pick up some 04-07 Impreza rear mounts, which are stronger, along with W0406-22 bushings for them.
It's exactly what I'm doing. When I build Robi's car I'm going to ask for some of my payment in whiteline parts.
Where do I get the bushings for the impreza mounts?
My WRX wagon front sway bar is out for delivery right now! Should be here when I wake up.
