oil dissapearing!!!
oil dissapearing!!!
I have 800 miles on my current oil change and checked it the other day and the level was all the way down to low, the car has 246000 miles on it and i know it will probably be using some oil but why so much, also I noticed oil around the outside of the filter, i checked it and it was on tight, any ideas?
It's not shooting out a blue cloud when you get on it by any chance or when its just idling? Mmm if there's alot around the filter it could possibly be your oil pan gasket. Could also be the front or rear main seal and with those high mileage it is very likely these need to be replaced also it could be coming out of the valve cover.
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
Where else is there oil on the engine besides around the filter? Also when where these seals replaced?
flatoutfred
Maybe you already know it but you have to check your oil when engine is warm but not too much and you have to wait 5 minutes after the engine is shut down to let the oil come down in the pan.
Lots of people have trouble to check their oil level.
Legacy turbo, desnorkled, intercooled, TD04, Borla catback, urethane mounts, wrx rear brakes.
