can someone please point me in the right direction? 91 ss 4eat with the nippon abs unit
all i can see under the dash is two black connections and two green connections, and one white one far up with a sort of cap/insert covering it.
is it one of these? where is the L terminal?
clearning/checking abs light
Summer Fun = 1991 Civic Si Turbo
Winter Fun = 1991 Legacy Sport Sedan
The one you are looking for is near the fuse box on the floor. It is a green connector you need to remove. It is a small green wire. All you do is ground one of the pins and the abs light will flash. Let me get you some links.
Over here i see these wires. I recall seeing these two wires dangling with my car, never used them though to find my codes. I use the green wire near the fuse box on the driver side floor.
http://forums.nasioc.com/forums/attachm ... 1022337814
This is a good PDF
http://www.endwrench.com/pdf/brakes/FtSubaruABSS99.pdf
This is a good PDF
Here is more. Alot of abs info on USMB.
http://www.ultimatesubaru.org/forum/sho ... light+code
To much reading about the abs unit im off to bed lol.
I am of course assuming that you have found the connector and checked the codes already. all i'm saying is that the the light will be off until you srat driving again and it senses a problem again until you fix it.juice91si wrote:magicmike wrote:the light should go away once the problem is gone.
the plug is a green plug that is not connected to anything. you may or may not find a black wire taped to the harness that you can pull out to stick into the green plug one pin at a time. This was wired into some cars from what i hear. you can just jam a wire into one of the terminals and ground it, turn the ign on and it will start flashing codes.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
