UHEV Legacy Version 2.0
I'm starting this thread now since I've actually had some progress. Maybe move to Build Journals? I'll be updating this on weekly basis, since I only have friday nights to work on it due to 16 credits and two jobs. :(
1st gen Legacy, current mods
Engine: 1991 EJ22T
Wiseco Pistons
Eagle Rods
Balanced & Blueprinted
Clevite Main Bearings
Cobb “race” rod bearings
Delta Camshafts
Garrett GT2871r 56T turbo
TiAL 44mm wastegate
Custom pipeset
Custom IC plumbing
Modified WRX TBE
Spearco FMIC
TiAL BOV
Koyo radiator
Slim fans
Custom lower radiator support
Diamond coilpack
Magnecor plug wires
Aeromotive A1000-6 FPR
Aeroquip fuel lines & fittings
Outfront Motorsports fuel rail adapters
Deatschwerks 650cc SR20 injectors
Link Plus G2 ECU
Zeitronix wideband w/ EGT 3.5 bar MAP sensor
MAC BCS
Driveline:
’05 STi 6 speed
Exedy Hyper Single clutch
’99 Imrpeza RS rear VLSD
K4RT30Y rear shifter bushing
Spiider’s Auto DCCD controller
Suspension:
H&R coilovers
RacingBrake 16” 4 pot kit
Hawk HPS pads
Goodridge lines
Energy Suspension bushing kit
SuperPro steering rack, lateral link, tranny x-member bushings
Whiteline Anti-lift kit
Strut tower bar
Lower H-brace
Interior:
Autometer boost, oil pres, water temp gauges
’93 Legacy Sport Sedan interior
What's changing:
'98 DOHC heads
Modified (again :lol: ) pipeset
Larger IC
COP
revised fuel system
much cleaner wiring
Opera Tuning style chassis reinforcements
tubular bumper beam
R180 + Hybrid axles
and plenty of other things I may decide to change along the way.
The car previously:
Crunch!
Where I'm at:
This will need to be cut apart, extended for the DOHC heads, flex joint removed, etc.
Opera Tuning is a shop in Japan that uses factory sheetmetal over the top of existing sheetmetal to reinforce the car. I'll be doing this in some key areas since the old Legacy is damn near a wet noodle by todays standards of chassis rigidity. You can see what I removed here. I think there was almost 30 spotwelds on each one...
I pledge allegiance...
That's it for now. There is A LOT of stuff that needs to be stripped from the car. I don't have another car as of yet, but will in late january or early february. There's no shortage of stuff to do right now, so there's no rush on getting a shell here.
Last edited by 93forestpearl on Mon Apr 06, 2009 3:23 am, edited 2 times in total.
94SS_Canada
Post by 94SS_Canada »
BaBaBaBaBaBuild journal.
Looks good.
FastRust
^ I'm not allowed to start a thread in there.
Oh and I started working on this too, lol.
94SS_Canada
hahahahaha, Awesome. You must pm the mods to start a thread, unless you were booted.
FastRust
I figured I'd start it, and when one of them see's it, they can move it over there. If not, NBD.
Nice work, and lots of it.
+1 for the champagne of beers.
Nice work Dan!
I'll get you setup.
Thanks Josh. Not much to show just yet. I want the car stripped and out of the garage before I start on the motor and fuel system stuff.
You should be good.
livestrong14
Post by livestrong14 »
Awesome work man! I love your project! Can't wait to see how it turns out!
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
Last night's progress:
Finding somewhere to put all this stuff is fun...
Interior fasteners thus far
:shock:
And I made some money while I was at it :-D
The coolest part is that I get to do this all over again when I get another car :(
Looks fun Dan ;)
I don't envy a complete tear down....
Dropping the crossmembers with everything still attached makes life easier. If I had a lift, it would be gravy. It sucks with the car on stands and rolling around underneath it.
Plus, it takes about 8 hours with the heater on to get the floor to warm up at all.
I might be buying a car tomorrow. Apparently, it has a little surface rust. We'll see.
http://minneapolis.craigslist.org/cto/952055781.html
cartwheels
Post by cartwheels »
Sweet. God I love browsing craigslist for cars under a grand.
1994 Legacy TW
1991 Legacy SS
1990 VW Vanagon Westfalia
No dice on that car. The corners were pretty bad and there was a lot of hail damage, which he neglected to mention on the phone. Oh well. It never hurts to look.
Sure it can—ever seen a schizer video? I thought it would be funny. It wasn't.
I had enough of the fam stuff so I went out to my man-cave. I decided to do a little work to my intake manifold and fuel system.
I did the welding on on the intake a few weeks ago at Matt's place. It is pretty ugly, as I had never welded on cast aluminum before. If I would have known at the time, I would have messed with the balance control to get better penetration. Oh well.
skid542
Post by skid542 »
Oh man that intake looks clean. I love the fuel system, so much cleaner and simpler. Would you mind sharing a few of the specifics?
I wish you the best with the 'rebuild' and look forward to seeing everything get put together. You've always had nice installs.
Lee
skid542 wrote:Oh man that intake looks clean. I love the fuel system, so much cleaner and simpler. Would you mind sharing a few of the specifics?
No prob. The regulator is the Areomotive A1000 -6 injected bypass regulator. Pretty much the standard unit when it comes to custom fuel systems do to it's reliability and versatility.
The plate below it is just a piece of 1/16" aluminum I had laying around. I may change the mounting scheme later.
The line and fittings are all Aeroquip stuff. I've worked with Earl's hose ends before, and never will again. They were a huge pain to get started. Plus, Aeroquip is a division of Eaton who is local to me.
The fuel rail adapters are from Outfront Motorsports. They do a lot of sandrails with subaru engines. The adapter can be used on all but one end of the rails, being the end where the factory regulator used to be. On this end, you can simply use a 1/4 NPT tap without drilling it to tap it out to put whatever fitting in there you desire.
I can't put together the feed side of the rails yet as I still need to get a fuel Y-block, and I really can't do it until the intake is on the motor, and possibly in the car.
Thanks for the best wishes. I'll try to keep the whole process well documented.
Grayguy
Post by Grayguy »
Are you still running "just" the walraro 255 in-tank pump?
92' SS: SOLD
94SS_Canada
Give me my Canadian money back!
Looks good! love the fuel system, where are you putting the coil? just offsetting it?
FastRust
Grayguy wrote:Are you still running "just" the walraro 255 in-tank pump?
For now. IT is plenty for my particular turbo. If I upsize, I'll go to two walbro's though. I'm currently debating running my own -8 from the tank to the possibly stock filter while it is apart. That's about a $100 decision though.
94SS_Canada wrote: where are you putting the coil? just offsetting it?
I'm going to coil-on-plug, since they bolt on to these heads. The newer style COP may bolt on to older heads, but someone else would have to verify it.
livestrong14
Very cool setup man! cheers!
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
