Stock WRX DP on SS?
Stock WRX DP on SS?
if we put a stock WRX downpipe onto my 91 SS, and extend the O2 sensor to go into the bung, will it make it run weird? because there are 2 cats before the sensor.
somebody mentioned that it might run rich, is that true?
'91 Turbo Stanky Leg
I have a WRX downpipe on my 91 SS. The installer welded in an O2 bung in the same location as the stock downpipe. It's worked fine for tens of thousands of miles. Seems to me that extending the sensor to the stock WRX location is more likely to cause out of range data for the ECU.
-steve-
03 Legacy L Wagon
91 Legacy Sport Sedan - SOLD
03 Legacy L Wagon
The WRX has it's O2 sensor before the up-pipe because of all the catalytic convertors. Placing it after any catalytic will most likely cause a rich condition in closed loop driving.
Sounds like you found a catless dp. But i have a bellmouth 3" dp i'm looking how much you willin to spend?
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
i just put a perrin divorced downpipe from a rex on my car, i plugged the 02 bung and welded an 18mm fine thread nut in our stock location. running an 02 after the cat is a bad idea as the 02 controls so much and when not working properly can cause alot of problems.
i would get that changed asap.
it's a good idea for building an exhaust off of though.
