205/60-16 fits?
dman
205/60-16 fits?
Post by dman »
Need 4 winter tires, gonna put those on wrx wheels, 205/60-16 has better/cheaper options, but not sure it fits and does not rub on suspension?
Remember some relevant thread but could not find it for some reason.
94 SS 5spd ABM
That may be a little too tall. The stock WRX tires 205/55 r16 only have about 1/8" clearance on the rear struts.
dman
Post by dman »
Legacy777 wrote:That may be a little too tall. The stock WRX tires 205/55 r16 only have about 1/8" clearance on the rear struts.
Well, on mine stock WRXs and remaining 3 RSIs clearance is about 1/4" but I guess that would heavily depend on the tire and luck.
Found this though, which is 215/60-16 and is a hair off rubbing (and probably does under cornering). So I'm probably not going to risk it.
94 SS 5spd ABM
impreza_GC8
Post by impreza_GC8 »
A 60 sidewall is like an Outback tire. Those are pretty dang tall. I'd say no dice.
-'97 Outback - EJ25 block/pistons/HLA heads, EJ22T crank/rods/ECU, EJ20G intake manifold/fuel rails/440cc injectors, VF8 @ 11psi. . . . Fuel cut > me
legacymax
Post by legacymax »
I am currently running 205/60 r16 hankook w409 studded and they fit on my 94 tw with ground controls(so a little different) and on my 95 impreza coupe with wrx wagon take offs both with no rubbing.
95 impreza Rally car. 3.0 H6
88 Toyota fj62 OME lift.
94LegWagon
Post by 94LegWagon »
I am running 205/55/16 and would say any taller of a tire and i would rub.
94 Legacy Wagon N/A 5mt AWD
Bdub
Post by Bdub »
94LegWagon wrote:I am running 205/55/16 and would say any taller of a tire and i would rub.
I am running these as well, and I'm going to downsize to a 205/50/16, because at some points the tires slightly touch the spring seat on the strut.
Through The Generations...
91 SS 4eat
95 LSi 4eat- Sold
07 2.5i 5mt- For Sale
13 STI Sedan
