Cold Highway operating temp
courtjesterclown
Post by courtjesterclown »
the past two trips i have made with the car(94 SS 4EAT) it has been cold outside, under 25 deg. F. So i go out and start the car up and at idle it comes up to temperature (half way on the gauge) like it should and the heater blows hot air. But as soon as i hit the freeway and increased speed brings the temp gauge all the way down to the Cold mark and the heater no longer blows air. As soon as i pull over and sit at idle again after about five minutes the temperature gauge rises back up to halfway and the heater blows hot air again. I know that it cant be good for the engine driving at Cold like that, does anyone have any suggestions for what the problem could be? Any help is appreciiated. Thanks.
1994 SS 4EAT Aegean Blue Metallic
PhyrraM
Post by PhyrraM »
Check the thermostat. Alot of people still replace thier thermostat with low temperature ones or leave them out altogether. Both are completely unneccisary.
Might also be your radiator hoses. Is it fine around town? If the hoses feel really squishy, they could be collapsing at speed.
BXSS
Post by BXSS »
My OBS has a Koyo Rad on it & @ temps below 50* 60+MPH Highway cruise speed cause coolant temps to drop to about 140*.
I plan on making a cardboard plate to block off part of the radiator behind the grille / painted black - stealth trucker style.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
If you make the blank off plate for the grille(s) itself, you'll reduce cooling while improving aero efficiency.
log1call
Post by log1call »
It will be your thermostat. Their job is to get the motor up to heat and to keep it there. It is a cheap part and fairly easy to change. It's a good idea to change it every two years or so when you are changing the anti-freeze.
