so the other day i decide its time to clean out some shit in the trunk and i open it and everything is wet, i look at the lid of the trunk and there is water build up on it almost like condensation.
but i look under the multibox and there is a POOL of water. WTF so i drain it out n shit then discover there is more on the left side were the jack is and there is condensation all over the side wall. this is only happening on the left side of the trunk the right side is dry(except for the lid) i did a little test to see if i can find where the source is but was unsuccessful. anyone have any ideas? or have this problem them self?
mystery leak
mystery leak
[quote="kimokalihi"]Jesus, that's a grocery list of problems.[/quote]
92 Legacy SS 5MT....sold :(
02 Aspen white WRX Stage 2, 20%tint
I made small holes in the rubber grommets under the spare tire. And drilled a hole at the bottom of each of those "nooks" (under tire jack and opposite side of the car). No more water problems
You may be getting water in from the flapper vents or from the sunroof drains.
