JDM STi v.5/6 suspension?
Does anybody run JDM STi suspension (stuts/springs) on their Legacies? I'm curious as to ride height vs. stock, and if anything besides normal GC fitment issues arise.
1991 SS build thread: http://bbs.legacycentral.org/viewtopic.php?t=40430
I run STI Tarmac/gymkhana springs on my Impreza wagon for Autox. They have excellent spring rates and provide a very firm ride when coupled with struts that have enough dampening power. I believe the suspension sticky gives example spring rates to give you some ideas.
What do you want to use the setup for?
SUBARUEHS Racing
n2x4 - yeah, I saw the listed rates. I plan on using this for daily driving (the SS is my fun commuter) and the occasional autocross.
I am currently debating AGX or G2 struts, and may just go with the G2's since I won't be racing the car.
There is a set of v.5 STi suspension available locally, but in light of the comments on used struts, I may just get new ones and consider the STi springs only.
So, STi springs + G2 struts, or should I get new aftermarket springs too?
Well,
Lets say the stock strut is designed to handle dampening for the stock spring with a rate of 132lb.
A GR2 is roughly equal to stock strut + 15%. So it's good for a rate of
132x1.15=152. As I said, that's rough, so I could see the GR2 working well with Eibach, whiteline, intrax, etc.
A AGX has 4 settings for the front (8 in the rear). It's max is stock strut +123 so
132x2.23= 294lb.
Version 5&6 springs are all in the low 200lb. range, which mates up very well with the AGX at setting 3 or 4.
Those numbers are not 100% correct, but they should give you a rough idea of what to expect.
I say that if you get a good deal on the STI, go with those and the AGX.
132x2.23= 294lb.
SUBARUEHS Racing
