Bad compression and 1 new engine...
Posted: Thu Jan 11, 2001 8:28 pm
by jason grahn
well i just got my back from the technitians scapel, and i'm got ~150 lbs.
of compression in 3 of 4 cylinders.. Cyl. #2 only has 100lbs. It will run,
but not tip top. =(
SOOOOOO... seeing as how i have such wonderful access to subaru parts from
my new job, i'm going to start a project engine. Most likely a low
compression supercharged jobbie or try to build it to get the ultimate
highway milage.
>From the death of the phoenix, rises anew.... We shall see, we shall see.
Jason
_________________________________________________________________
Get your FREE download of MSN Explorer at http://explorer.msn.com
Posted: Fri Jan 12, 2001 8:38 am
by Gary Grahn
Now when did this happen? I don't remember hearing anything 'bout this?
You should be getting that turbo 2.2 block, Jay. :)
Later,
Gary
>From: "jason grahn" <jgrahn555@hotmail.com>
>Reply-To: BC-BFLegacyWorks@egroups.com
>Subject: [BC-BFLegacyWorks] Bad compression and 1 new engine...
>Date: Wed, 10 Jan 2001 14:38:46 -0800
>but not tip top. =(
>highway milage.
>Jason
Posted: Sat Jan 13, 2001 7:58 am
by Rod Grosvenor
Jason-Sorry about the news; I`m going through the same thing, but it was
suggested that I may have cam lobes that are worn & may contribute to the
lower cylinder reading. Interesting that in 3 cases posted here, only 1 cyl
has been down & the rest perfectly ok. Anyone else run into this? Also, I
posted to Scott @ Subaru parts & never heard a thing; I used your name as a
referral. Maybe @ your new job you can help with a used, late set of 2.2 NA
heads & cams that`ll fit my `92 motor. I`m planning on sending them to Trey
@ Cobb tuning for sreet-type headwork & cam profile + a boost in compression
to about 10.5 to 1 (Ialready have to run premium due to a piggy-back chip).
Any info woukd be appreciated-ROD (somewhere in No. Az.)
----- Original Message -----
To: <BC-BFLegacyWorks@egroups.com>
Sent: Wednesday, January 10, 2001 3:38 PM
> but not tip top. =(
> highway milage.
> Jason
