Anyone running with a Manual Boost Controller?
xxchevypwrxx
Post by xxchevypwrxx »
Does anyone have one of these currently on their car? i just purchased one but it didn't come with instructions, i tried to put it on the car but from 10psi it came down to 5psi, then i turned the screw like 5 times inward and outward and it just keep dying trying to spool up the car. Can anyone help :!: thnx
1991 Subaru Legacy SS , FMIC,ROYAL PURPLE OIL's,REVTRONIX CHIP,Custom exhaust from turbo to muffler,k&n filter,custom piping,stock turbo pushing 15psi of boost!
BSOD2600
Post by BSOD2600 »
Yes, many of us are running MBCs. Search the forum. Post pics of what you've got/installed.
'11 WRX Limited
'94 TW | R.I.P.
xxchevypwrxx
Sorry i dont have a camera, but i just need to know what is the correct way of putting it on,thnx.
Aerotech
Post by Aerotech »
Did it come with a "leak pill"? ... goes in the vac line between the manifold and the MBC, has a very small hole in it?
Need that to fake out the wastegate into staying closed longer.
Jerry
RJ93SS
Post by RJ93SS »
you say revtronix chip but ur using a boost controller???
wtf
wtdash
Post by wtdash »
RJ93SS wrote:you say revtronix chip but ur using a boost controller???
wtf
+1
Don't think you want both the chip and an MBC, do you?
If you don't have the chip, then do a search for the Hallman Boost controller on here...it should/could/would/may be the same, or THIS.
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
xxchevypwrxx
yeah it does have that small hole, the chip gave me 10psi but i want the 15psi
wtdash
Post by wtdash »
What did Revtronix say about 15 psi w/their chip?
Since they recommend/require other mods to use the Stage 2 chips to get to the 14/17.
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
