Stock Flywheel Help!
Does anyone know where to buy a stock flywheel anywhere? Every single place that I call has a flywheel, but nobody has a TURBO flywheel. Advanced Auto said they had the right one, but they didn't. I've called Napa, Pepboys, Autozone, and looked online everywhere. The only Flywheels that I can find are light weight ones, which cost 200-500 dollars. I haven't found any auto parts stores that know that the N/A and Turbo flywheels are different. Also does anyone know if there is any other Subaru cars that share the same flywheel? Possibly a newer WRX? Any help would be appreciated.
Ask for a '02-'05 WRX Flywheel. Common and 100% interchangeable. I would also start using WRX clutches too, but EJ22T ones will work with the WRX flywheel.
