intrcooler
Locked
Mike Danilowicz
intrcooler
Post by Mike Danilowicz »
I have a liquid to air intercooler on my turbo legacy... i have it
hooked up through the coolent lines so it cools through the
radiator... I got rid of that little resavoir and used it as one..
--- In BC-BFLegacyWorks@egroups.com, "dfullerton" <dfullerton@d...>
wrote:
> Any guy out there with water cooled intercooler could you please
tell me the wright fluid to top it up with also is there a level to
read or has it got to be filled to the top.
dfullerton
intrcooler
Post by dfullerton »
Any guy out there with water cooled intercooler could you please tell me the wright fluid to top it up with also is there a level to read or has it got to be filled to the top.
eGroups Sponsor
<http://rd.yahoo.com/M=169066.1281467.28 ... EY=ECAALR4> Click Here!
penty
intrcooler
Post by penty »
mines at the top as it doesn't expand much because it never gets that hot
----- Original Message -----
From: dfullerton <mailto:dfullerton@dfullerton.screaming.net>
To: BC-BFLegacyWorks@egroups.com
Sent: Friday, January 12, 2001 12:32 PM
Subject: [BC-BFLegacyWorks] intrcooler
eGroups Sponsor
<http://rd.yahoo.com/M=169066.1281467.28 ... EY=FOBTGG1> Click Here!
JohnnyG
intrcooler
Post by JohnnyG »
Ummm... I can't agree that this is appropriate. I would think that the
engine coolant / radiator would run a lot hotter than the factory
intercoooler coolant / reservoir.
John Gillon
www.clubsub.org.nz
To: <BC-BFLegacyWorks@egroups.com>
Sent: Saturday, January 13, 2001 1:14 AM
Subject: [BC-BFLegacyWorks] Re: intrcooler
Rod
intrcooler
Post by Rod »
use the same as whats in your radiator.... ie, distilled water with a anti freeze or anti corrosion depending on your circumstance. fill it up to the top as you would a radiator.
rod
Sent: Friday, January 12, 2001 11:32 PM
eGroups Sponsor
<http://rd.yahoo.com/M=169066.1281467.28 ... EY=ECAAQM0> Click Here!
Rod
intrcooler
Post by Rod »
yes, i agree with that assumption.
all you need do is feel the intercooler radiator after a drive and it is
cool, ambiant air temp.
compared to the engine radiator which runs hot, ie, there is a thermostat to
keep constant operating temp.
no thermostat in the intercooler system.
rod
Sent: Saturday, January 13, 2001 7:48 AM
Subject: Re: [BC-BFLegacyWorks] Re: intrcooler
> John Gillon
> www.clubsub.org.nz
> From: Mike Danilowicz <subaruracer755@cs.com>
Locked
