aftermarket radio problem...HELP....
pascooby
Post by pascooby »
So my 93 legacy l has an aftermarket stereo in it when i got the car it worked great. well soon after there would be no noise at all through the speakers which are aftermarket cheapies when you would hit a bump the music would come on then when you hit another bump there would be dead silence. so i took the stereo out and found the speaker wire connector was kinda messed up when you wiggled the connector the music would start to play then stop instantly so i cut the connector out and soldered the wires together. still no music at all and yes all the wires are going to there correct coresponding wires and suggestions
pascooby
Post by pascooby »
sorry to waste everyones time i found it it was just a shoty install job i got alot of soldering to do. thanks
