so after about 2 years i have finally got to the point where i am able to afford my control springs from whiteline. i had choosen these since i have front and rear sway bars so i wanted to stick with whiteline and since i can get them cheap.
BUT now i find out they are discontinued . i would have only had to pay at most 300 and a i would have been able to pick then up, no need for shipping. so where to look H&R, i cant tell if they fit or not
so now i am looking some ground control coilover conversion kit.
they are for the 93-01 impreza but if have read correctly they will fit. this is going by the sticky. the question that i have is you can get 7'', 8'', or 9''. the 7'' has the lowest drop and 9'' has the least. in the sticky Jamal says you want the highest of atleast 8'' but i could get 9''. but i want the car to be lower so which do i chose. also what spring rate i chose considering i dont really know what that means. i guess how soft or stiff?
well if your doing just springs no. you will need the 04+ front top mounts. if you go for the 04+ coil overs then im pretty sure they will bolt up no problems, no mods
i will lokk when i get the chance i have been working so much that i seem to forget every time i step into my car. but about the coilovers how exactly do they get installed. i am kind of confused on that. i am going to be buying ground control coilovers i think
