Phase 2 EJ22 cams
Parts and services from sanctioned vendors and businesses.
Delta Cam
Vendor
Vendor
Phase 2 EJ22 cams
Post by Delta Cam »
I have a set of phase 2 EJ22 with torque grind.
We are offering these for $93.50ea plus $75.00 core ea.
Give me a shout if you are interested.
Ken
Delta Cam/Custom Import Heads
1-800-562-5500
Delta Cam
Vendor
Vendor
Post by Delta Cam »
Somebody has to want more power!?!
What are you looking for? Let us know. We can and will help you get affordable power.
Delta Cam
Vendor
Vendor
Post by Delta Cam »
Do we have any interest in performance boosting parts here? Either heads and/or cams?
logan9691
Post by logan9691 »
do u have ne DOHC heads?
Delta Cam
Vendor
Vendor
Post by Delta Cam »
logan9691 wrote:do u have ne DOHC heads?
Yes, we have some cores and a couple of sets already done in stock form. What are you looking for? Year and build?
Ken
Saskatoon Subaru
Post by Saskatoon Subaru »
what kind of gains are there to be had from these cams?
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
Just curious, how much for cams for EJ20 DOHC?
Delta Cam
Vendor
Vendor
Post by Delta Cam »
Saskatoon Subaru wrote:what kind of gains are there to be had from these cams?
10-15% gains depending on supporting mods you could see a bit more.
Delta Cam
Vendor
Vendor
Post by Delta Cam »
kimokalihi wrote:Just curious, how much for cams for EJ20 DOHC?
Depends on whether or not you plan to do head/valve work at the same time. If you do not plan to do head work then the cams have to be welded and ground. This is $150.00/cam($600.00) If you do head work it is $500 for the cams, you also get new oversized(.5mm) valves with overlength stems.
Give a call at the shop and I can probably explain it better that way.
Ken
1-800-562-5500
greg donovan
Post by greg donovan »
i am planning out a winter project and want some ej22 cams with the torque grind to use in a ej25 shortblock with ej22 dual port heads.
if i send you a set of cams do i still need to pay the core charge?
96 Impreza L sedan
97 legacy outback limited
00 Impreza RS sedan
Post by SILINC3R »
looking for the street cams for a 1990 N/A legacy SOHC
Delta Cam
Vendor
Vendor
Post by Delta Cam »
greg donovan wrote:i am planning out a winter project and want some ej22 cams with the torque grind to use in a ej25 shortblock with ej22 dual port heads.
SILINC3R wrote:looking for the street cams for a 1990 N/A legacy SOHC
Wow, sorry I missed these questions.
No core charge when done on your cams. We have done a couple of these builds recently.
We have a few grinds available for you guys. Give us a call @ the shop.
Ken
1-800-562-5500[/quote]
yazmo
Post by yazmo »
where you are locate at?
Delta Cam
Vendor
Vendor
Post by Delta Cam »
We are in Tacoma Wa.
Post by SILINC3R »
i be visiting in the future
Delta Cam
Vendor
Vendor
Post by Delta Cam »
SILINC3R wrote:i be visiting in the future
Perfect, call if you need directions.
Jon Bodwell
Delta Cam / Custom Import Heads
92legacyL
Re: Phase 2 EJ22 cams
Post by 92legacyL »
do you make just a sohc for my ej22 n/a i just want a little more horsepower
Post by SILINC3R »
yes they do, they have 1 and 2 stage and maybe a 3rd stage for us N/A guys. they are pretty great deal too.
92legacyL
Post by 92legacyL »
how muxh does a stage 2 cost
Out the door with shipping it's going to cost you a little less than $200.
92legacyL
Post by 92legacyL »
i wont have to do valve work or anything right i just am upgrading my exhaust system and wanted to know
Post by SILINC3R »
you dont have to but i would recommend it if you are going to have the heads off anyway. also usually you want to have them resurfaced and of course get new gaskets and even do the cam seals while your at it. thats is what i would do
92legacyL
Post by 92legacyL »
how much will that all cost
Delta Cam
Vendor
Vendor
Post by Delta Cam »
That depends. Which engine do you have, phase1 or phase2? We have valves for phase2 only. The valves cost $225/set.
Ken
Jon Bodwell
SubyFusion
Post by SubyFusion »
Do you sell cams for an EJ20 N/A engine? let me know thanks,
VBR
Brian
