clutch going out?
boarderbw
clutch going out?
Post by boarderbw »
ok so im driving on the interstate and i punch the gas and the rpms go up way faster than i accelerate. this has to be a worn out clutch right? i dont notice it slipping at lower speeds
1991 legacy turbo
yeah, probably the clutch.
boarderbw
Post by boarderbw »
thanks thats what i figured. i just thought i would notice it more in lower gears. i only notice it in 4th and 5th
1991 legacy turbo
PhyrraM
Post by PhyrraM »
boarderbw wrote:......... only notice it in 4th and 5th
While that may seem backwards, it's perfectly normal.
It's actually a good sign. It means that your clutch is worn out, but normally. Your not likely to encounter any other other problems once your into the job.
Post by entirelyturbo »
A worn-out clutch slips in high gear simply by virtue of the tall gear ratios. Regardless of the car's speed, accelerating puts a higher load on the engine (and therefore clutch) in a high gear than a low gear.
I would suggest that you begin sourcing replacement parts or get an appointment set up with a shop very soon. In my experience, if it's starting to slip, it probably doesn't have that much longer.
*Formerly DerFahrer*
Yeah when my clutch started slipping in my toyota pickup 4x4 89 I think it lasted about a month until I couldn't drive up a hill period in it. It would get going up the hill in 2nd gear and then slow down to a stop and roll backwards while you could hear the clutch spinning on the flywheel surface. See and smell smoke.
But that's with me wheeling the shit out of it all the time with the clutch slipping.
Soul Shinobi
Post by Soul Shinobi »
I couldn't find a sticky, or a topic by searching, on how to replace the clutch. I need a clutch really bad too, it'll slip in any gear now if I give it too much gas...
I thought I read on here a while ago about one of you guys pulling the engine forward instead of dropping the tranny, is that really doable?
What's a good bang for your buck clutch? I know the OEM ones will last a long time, but I've heard about you guys throwing eBay ones on, do those really perform acceptably?
-Nick
1992 BC Legacy L Sedan AWD 5MT 272,000 - Wish you the best
1998 BK Legacy L Wagon 5MT 234,000 miles - RIP
2002 SF Forester S Wagon 5MT 215,000 miles - Current winter sleigh
1986 FC Mazda RX-7 GXL Coupe 5MT 155,000 miles - Summer cruiser
I would take the transmission out. Less wiring to mess with, and you don't need a cherry-picker.
Get a good clutch. Regardless of which way you do it, it is labor-intensive, so you probably won't want to do it again after only 30k miles because you bought a crappy clutch.
Soul Shinobi
Sound advice. Are there any non-OEM clutches that are good quality? If I had the money I wouldn't think twice about getting an OEM... I know an OEM unit with everything minus flywheel is around $250. What's labor usually cost at a non-dealer shop?
-Nick
Soul Shinobi
It was brought to my attention in another topic the Exedy clutch kits can be had on eBay for around $150. Are these good? I'm under the impression that Exedy is a good company.
Also, the flywheel on the engine I'm rebuilding has signs of massive overheating, can it still be machined? Either way, what a good cost effective replacement?
EDIT: Interestingly, Exedy says they do not condone purchasing from eBay (of course, they want you to go to a proper supplier) but they even have a PDF that shows how to identify a counterfeit: http://www.exedyusa.com/oe/faq.php
-Nick
tturnpaw
Post by tturnpaw »
The luk clutches you get from Autozone are great. Many people don't realize luk is also a twin company to centerforce and they both make great clutches. As for the flywheel, you can usually get about five resurfaces done before they need replacement. I've had a flywheel that had massive overheating cracks on the surface from slipping the clutch with high horsepower and it was still able to be resurfaced.
boarderbw
Post by boarderbw »
as soon as i get my tax return which will be in a day or two im gonna order a competition clutch kit from maperformance.com. they are 375 which is cheap compared to act clutch at 575
1991 legacy turbo
