N/A knock sensor same as turbo?
Hey guys. I still have a knock sensor code, but it's funny because when I drive at a steady pace the check engine lights goes out. Once you stop and idle, it's back on. I also noticed the car has significantly more power when the check engine light is off. I am thinking ill swap sensors from my n/a for now. I was also thinking I can just clean the original sensor and spray alot of wd40 in between the crack. Supposedly what creates the code is moisture right?
Is this knock sensor alright?
http://www.autopartsway.ca/autoparts2/i ... rbo~240906
Doesn't bosch make the OEM one?
