if not pictured, ask and may receive...
Not pictured: Ej22T crank (perfect Condition)
Open to any offers, because most will probably be honored. just some extra cash for new build which im almost done calculating. I dont wanna let the cat outta the back until im close to finishing.
2.2 Intake Mani plug and Play (550 cc injectors installed) Can separate if necessary
2.2 Dished turbo pistons - I have 5 good ones (ofcourse only 4 will be needed lol)
Set of 2.2 SOHC heads
Set of 2.5 SOHC heads (from Joe's forester - jellied grease just needs cleaned out.. came off running car)
Popped 2.2 Case - workable after a good hone job
