WTB: TMIC, Turbo, and all necessary piping for 92 legacy
tweeeqd
Post by tweeeqd »
I've asked before, but now I have the money. thanks to all of those who responded before.
To my understanding, most parts from newer wrx's will fit my car. This is what I would prefer, unless you can suggest something better for around the same price. I'm looking to spend around 300, but i can go higher. I have seen this package off a 2003 wrx for 300.
92 Leg
RJ93SS
Post by RJ93SS »
you can post this in the parts shed, for 300, you can get a td04, 06 i/c and silicone hoses plus gaskets. maybe even less.
read this thread http://bbs.legacycentral.org/viewtopic.php?t=38598
and thishttp://bbs.legacycentral.org/viewtopic.php?t=38312
BXSS
Post by BXSS »
If you are turboing a ej22e I'd suggest a VF11 as a starter turbo as they are cheap & have a SAFE 5psi Actuator stock.
Once you get everything perfect @ 5 psi you can always raise boost some...
You may want to check out WRX headers & downpipes from e-bay as they are CHEAP then you just have to source the turbo (complete), TMIC, + fueling on boost.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
moving
tweeeqd
Post by tweeeqd »
thank you, thank you.
92 Leg
fastevo
Post by fastevo »
Sent you a PM. Regards, Steve
