03 and 04 WRX rear calipers
Post by SILINC3R »
is there a difference between the years. reading Jamal's thread i want to say no, but i am not positve
jamal
Vendor
Vendor
Post by jamal »
The calipers are definitely the same, or at least compatible. The bracket they attach to changed at some point in 02-03 to a different shape that uses different pads. You pretty much just have to look at them to see what pads to use. Also if you're doing H6 brackets almost any 97+ rear 1-pot caliper will work on them.
Post by SILINC3R »
im getting them off of NASIOC and im not sure if they are coming with brakets. but there is a 03 and 04 for sell just price difference.
