Cam sprocket removal
Bdub
Post by Bdub »
Without the special BS tool from subaru, what is a good way to remove the cam sprockets? I've tried a strap wrench, but I can't get a good enough amount of leverage.
I have the Tbelt already off, so I suppose I should have broken the bolts when I broke the crank pulley.
Anyone have any tricks they use?
Through The Generations...
91 SS 4eat
95 LSi 4eat- Sold
07 2.5i 5mt- For Sale
13 STI Sedan
SLODRIVE
Post by SLODRIVE »
Which engine are you working on? If it's an EJ22, the factory manual shows a picture of a flat-bladed screwdriver through the spokes of the sprocket to hold it while you loosen the bolt.
That's what I did, piece of cake...lol, I would have done it even if it wasn't in the manual!
http://www.slodriveracing.com
-And more!
Bdub
Post by Bdub »
Yeah, the ej22.
I was thinking about that, but just wanted some opinions before I did it. I have used plenty of tricks loosening these bolts on this engine, so I know I probably would have figured something out.
91 SS 4eat
95 LSi 4eat- Sold
13 STI Sedan
Or get a cam gear wrench if the screwdriver doesn't cut it.
douglas vincent
Post by douglas vincent »
HUGE ASS impact wrench, like a 3/4".... Thats what I use. In addition to NOTremovin the timing belt....
Bdub
Post by Bdub »
Unfortunately my compressor crapped out, because I sure wish I had that damn thing to break the bolts.
I used a wide chisel to jam the sprocket up, and that worked pretty good for the drivers side because there is a bolt behind it to gain leverage. The Pass. side looks like another challenge, but I've yet to get to it yet.
Unfortunately, all my parts I needed came today and found that I mistakenly forgot to order the crank seal and the Oring for the camshaft on the drivers side was what was leaking, not the oil seal itself. Damn!
91 SS 4eat
95 LSi 4eat- Sold
13 STI Sedan
