3" Turbo back exhaust install
wtdash
Post by wtdash »
I installed a 3" bellmouth DP from Ebay, w/a 3" in/out Magnaflow Hi-flow Cat (94139), and a 3" in/ dual 2.5" out Magnaflow muffler (12198).
In 'conservative/hands-off my guns' ID they have a law that makes modified exhausts illegal. That's part of the reason for the twin-tip - it still looks mostly stock.
The downpipe was a pain - had to enlarge all the mouth bolt holes and, since I have a AT trans, 'modify' the pipe near the trans hanger. But the hanger worked w/the stock location after a little modding - I just connected it by one bolt on the tranny side, rather than both. The good news was that the DP had the bung for the O2 in the stock location, and has another near the other end, if needed (wideband?). And the downpipe perfectly connected to the rest of the stock exhaust.
A local shop took the 3" midpipe I brought (was on a WRX), put in the cat, built a pipe for the axle back (not mandrel bent) and stuck on the muffler.
Sound? Noticeably louder, which isn't what I was after, so not sure it's going to be a long-term answer. I really don't want to attract attention - not my style. The sound isn't intrusive while cruising and doesn't really become an issue 'til 3K RPM which is below 70MPH, but it's loud @ idle in the a.m. while warming up. And @ WOT it may not wake the dead, but make 'em turn over. I've had it installed for a couple of months and decided to add a resonator, but it made little to no difference. My guess is it wasn't long enough (only 12") to help, but that was all I had room for.
Performance? I'm not sure it spools that much sooner (some see full boost <2K RPM!), but it's flows to redline faster and easier.... and seems to not want to stop @ 6500. The TCU/Rev limiter kicks in and it shifts before it runs out of breath. Overall it's a noticeable improvement over the stock system.
A couple of other notes...on my TD04 (never had this connected to a VF11), I was getting 12-13 psi (hitting fuel-cut on occasion) before I installed the Revtronix chip, even though the wastegate actuator is 10 psi. This may be boost creep caused by the larger exhaust and larger displacement EJ22T vs. the WRX's EJ20. Stock WRX exhaust is 2.25", I believe.
Downpipe:
Resonator:
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
Nice but no pictures?
Bdub
Post by Bdub »
+1 for some pics on the car.
My 3" is hanging kind of low to the ground where it loops under the diff., it isn't mandrel bent.
I'm thinking having a shop bend another piece to tuck it up closer to the diff. so it doesn't drag as I go about 80 down the dirt roads. :o
I also recently added a resonator because my muffler is loud as hell, and it maybe took it down a decibel, haha. Considering an STi takeoff or a used SPT to attract less attention.
Through The Generations...
91 SS 4eat
95 LSi 4eat- Sold
07 2.5i 5mt- For Sale
13 STI Sedan
wtdash
Post by wtdash »
Pics when time.....I'm still thinking of a STi axle back.
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
jbracefan1977
Re: 3" Turbo back exhaust install
Post by jbracefan1977 »
hey wtdash, hows the set-up doing so far? I just got 94139 and love it, they are cheaper on ebay but I wanted a warranty (the salt on the roads here in winter kills an exhaust) so I got it here magnaflow 94139, or you can try one of the vendors selling magnaflow exhaust system, they are always running sales/specials. either way its a great system and very easy to install. :-D :-D
