Battery and brake warning lights come on/off when running
redlines
Post by redlines »
I have a 93 legacy L wagon awd and recently the battery and brake warning lights will flash on and off for a few seconds they even seem to be staying on a little more now the more I drive it. The headlights and and even the dash lights are dimmer when they come on like its starving for juice. It seems like my alternator is going bad ? It still turns over just fine? Is it the alternator or do i need to decode it to be sure?
Saskatoon Subaru
Post by Saskatoon Subaru »
sounds like the alternator, i'd rip it apart to check.
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
redlines
Post by redlines »
Yeah the alternator looks to be original and its got 170K on it so hopefully thats all it is
Possibly check your connections and connectors on the alternator, and battery.
ultrasonic
Post by ultrasonic »
I had similar symptoms-- bad alternator.
-steve-
03 Legacy L Wagon
91 Legacy Sport Sedan - SOLD
redlines
Post by redlines »
ok thanks for all the help, any places online for a`quality alternator for a good price?
adema2626
Post by adema2626 »
rockauto.com generally has pretty good deals. Also gets to you in a reasonable time too.
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
Saskatoon Subaru
just a quick note. Alternators are very simple and easy to rebuild, and alot cheaper.
If it is more then just worn out brushes which I have found not the be the issue with more then one alternator then just get a reman. alternator. If the winning are bad or something else not worth the money to replace it as just the other parts can cost more then a reman alternator.
Saskatoon Subaru
i think you should find a new supplier
