Hi I got a 1993 Legact Nonturba AWD with a 5 speed. WHen it gets real warm >10 miles 3gear starts to grind on each shift. If I go slow it works fine.
I am thinking replace the tranny oil wioth some good synthetic. What do u all think?
Amsoil 75-90 full synthetic?
What do others use?
Anyone else have a similiar issue?
Is the Front Diff part of the tranny? Seems like it is.
terryg
1993 Legacy 2.2 5Speed AWD TRany Question
I've used redline and swepco to no avail. I swear these transmissons love whatever fluid the factory puts in them.
But it sounds like the fluid in your trans is broken down pretty bad. Try something with friction modifies for your synchros.
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
1988 4Runner RIP
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
Yeah that should work.
seems like with a manual it is the same part as the tranny. my old 95 imp. 5mt only had one stick which i assumed was for the tranny and front diff, seeing they both used the same gear oil.
as far as i know....
hmmmmm........ 94 turbo legacy maroon.
1995 impreza L sedan-r.i.p.
1997 cav z24 (seized the motor)
vroom vroom party starter!
You are correct. On the MT, the differential and trans gears share a common fluid.
