What best to build a 'sleeper' Legacy wagon (95)?
MikeC5
Post by MikeC5 »
As the title suggests, I'm thinking of swapping a hot engine into my plain-jane 95 Legacy wagon. Any thoughts on what would be the best compromise between power and ease of install? I know it would most likely require the ECU from the donor car.
ScottyS
Post by ScottyS »
I'm kinda curious about this too. I don't know if if would be te same amount of work to swap in a newer WRX wiring harness or just splice in a Turbo Legacy ECU and motor.
Obviously a newer setup would allow for easy DIY tuning, whereas the older legacy stuff would be a heck of a lot cheaper.
I have a N/A 95 LSi wagon that would love some power.
1991 SS build thread: http://bbs.legacycentral.org/viewtopic.php?t=40430
BXSS
Post by BXSS »
EJ20G's are cheap & share most of the wiring with SS's.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
Post by 555BCTurbo »
Put a 350 in it
MikeC5
Post by MikeC5 »
After doing a little searching, it appears the EJ20G is a turbo motor. I'm not clear on what years/models this engine was originally installed in (so I know what to ask for in the used part yards).
gijonas
Post by gijonas »
I have an eg33 you can stuff in there,someone needs to buy it before i decide to actually start another project with it.
asc_up
Post by asc_up »
Hmmm the only problem I can see with putting an EJ20G in there (which is an excellent choice) is that it is OBDI. If your car is OBDII, and I'm pretty sure it is, you might run into some trouble when you go in for an emissions test.
Step 1: Swap in newer 2.5L turbo motor
Step 2: Perform some wiring magic
Step 3: ???????
Step 4: SLEEPER!!!!!!
MikeC5
Post by MikeC5 »
It is OBD II...
ScottyS
Post by ScottyS »
gijonas wrote:I have an eg33 you can stuff in there,someone needs to buy it before i decide to actually start another project with it.
Those are awesome and bulletproof. I imagine a 6 is in my project future, but I'm trying to hold it off until a sweet SVX materializes at the same time as the funds.....
asc_up
Post by asc_up »
MikeC5 wrote:It is OBD II...
Sounds like your only stock turbo option is going to be a WRX or STi swap, unless you can find a way to get by using an OBDI engine.
There's also the option of boosting a non-turbo engine. My friend boosted his 2.5RS with a Garrett T3/04 on 7 PSI and made ~270 WHP. It's been reliable and running just fine for the past 2 years. Just throwing the idea out there...
Post by SILINC3R »
the only thing with this is that a N/A is a high compression engine so it isnt good for using a turbo. however if you use low boost like asc_up's friend is it will hold on but you cant do more than that
jp233
Post by jp233 »
true, but you can always lower the compression via various methods and then run a crazier boost if you want to.
(i dont know how easy it is on these motors, to run extra thick head gaskets etc etc)
But of course this whole thread has me thinking about when I get around to wanting to do something with my 94 wagon. I would not give one half-a-tenth-a-sheet about OBD 1 or 2 but a simple WRX swap sounds pretty easy compared to most...
12 Outback 3.6R Limited
94 Leg LS wag AWD, sold
93 Leg L wag FWD, sold
06 LGT 5EAT, project
asc_up
Post by asc_up »
Haha I'd probably do a WRX swap to if my car was stock N/A.
Going from OBDI to OBDII is not a problem, because they don't bother trying to plug anything into the diagnostics plug, because they'll think your car is OBDI. The problem occurs when you have an OBDII car with an OBDI engine and they ask to plug their scanner into the diagnostics plug and you don't have one/it doesn't work.
impreza_GC8
Post by impreza_GC8 »
I have a '97 Outback with 2.5L block, EJ22T crank and rods, EJ20G VF8 turbo and EJ20G intake manifold. It is run off an OBD1 EJ22T ECU. It is a fantastic sleeper.
asc_up wrote: My friend boosted his 2.5RS with a Garrett T3/04 on 7 PSI and made ~270 WHP. It's been reliable and running just fine for the past 2 years. Just throwing the idea out there...
What was your friend using for engine management?
-'97 Outback - EJ25 block/pistons/HLA heads, EJ22T crank/rods/ECU, EJ20G intake manifold/fuel rails/440cc injectors, VF8 @ 11psi. . . . Fuel cut > me
asc_up
Post by asc_up »
He was using an Apex'i S-AFC. Nothing fancy, but it got the job done.
impreza_GC8
asc_up wrote:He was using an Apex'i S-AFC. Nothing fancy, but it got the job done.
That is great news! I have been on the fence about using one but seeing those numbers you put up made me decide that it could be beneficial to me.
TammyB
Post by TammyB »
I have a 90's JDM RS RA motor that i need to sell please let me know if you need more info
