Tony's 90 Leg LS *SOLD*
Post by SILINC3R »
Well it all started from this, a 96 Grand Cherokee Limited
Mods:
new radiator
muffler
throttle body spacer
K&N intake $200 :shock:
Was pretty quick, and this is were my car interest started. Until the accident which happened 4 hours prior to my sister's wedding.
later that week my best freinds parents were giving their other sons car to charity and after they found out what happened they said they would eb give me the car. so i ended up getting it for $200 dollars :-D had 210xxx miles
this is close to the original car. one of the cvs was going already. the sunroof leaked and the air controls didnt work. the previous owner was on here or he knew of the forum cause he taold me about. he had the MAF adapter from Kartboy or from somewhere and put in a cone filter. he used to take it off roading and said he had it couple times on its side. guess thats how the sunroof cracked.
during that first summer i took the sunroof out and tried to fix it. took two attempts to get it right. fixed the air controls with a new one form a junk yard which was a newer model. used the Hanyes manual to figure the wires and spliced them together.
then i went to college and met a friend that got me more into car stuff like interior and what not. he had a Chevy Colbat that he was working on. he showed me how to install my lights and neons.
yes rice power, which i think added some power.
he also gave me this stupid little thing that you wire into the MAF and it has a nob that you turn to give you more horsepower. it kind of work but sometime after fried by using my dads truck to jump my car and somehow had the cables backwards :oops: . so got rid of that peice of crap.
then the summer of 2007 rolled around and it was time to start making things better. so i put in front and rear strut bars from TCSportline off of ebay which make really good bars.
after this i decided to do the struts all around. KYBs the basic ones i think. this was one of the hardest things i did. also did this myself and all these projects. from there i moved to doing the sway bars from whiteline with end lnks and such front and rear. also did steel brake lines
rearImage
frontImage
during this time i experimented with CAI designs and came up with this Image
work better than the stock
summer of 08 i put in a throttle body spacer from REASON
did some suede interior. headliner ended up not coming out well and the rear panel where the rear speakers are has faded. planning on black vinly next.
so now its 09 and i have redone the intake for the last time, put new rims 2005 Leg GTs, rear spacers to make the rears work, a newer mufller thanks to jp233, new ball joints, valve cover and lower oil filler gaskets and i think thats it, for now
well let me know what you think cause i will appreciate the input
L-Tuned BD
Post by L-Tuned BD »
Congratulations man that thing has come a long way!
Those wheels look great and I'm sure the swaybars and KYB's make it handle well to boot. I also like the latest CAI - looks quality. Keep up the good work.
'95 Legacy BK - L - Original Owner - Heritage Rebuild
'93 Legacy BC - SS Sold
'91 Legacy BC - LSi sold
'95 Legacy BD - L Sold
'09 Legacy 3.0R - Sold
hallowpoint
Post by hallowpoint »
WOW dude you car was riced out. but it looks like your bringing it together nicely. im sorry but the exhuast looks like crap. other then that keep up the good work.
inferno
Post by inferno »
Looking good buddy! Interior looks pretty classy. I love that lit up speedo dial! Where you get that from? Bet it handles well now!
Post by SILINC3R »
if you think the exhaust looks like crap you should have seen the old :D
i got the speedo and tach backlit gauges from ebay. there from an impreza. dont remember what year. it also came with fuel and water temp but they are reveresed on that car so i couldnt use em.
and yea it handles pretty well :D
thanks for the comments keep em coming
green91
Post by green91 »
You've made great improvements to the car, nice work! And you are semi local to me, i drive through jackson county pretty regularly.
Post by SILINC3R »
green91 wrote:You've made great improvements to the car, nice work! And you are semi local to me, i drive through jackson county pretty regularly.
really thats funny. isnt it kind of far. and thanks for the comments
green91
Post by green91 »
Not really.. i work in gainesville and my dad lives in Madison county so i go that direction a good bit.
Post by SILINC3R »
here is the pics from my WRX rotors and Calipers front and rear upgrade
front rotors
front all done
rear all done
now all i have to do is the front WRX springs. only problem is i dont know which springs are the fronts and which are the rears. also does it matter which side the springs go on. left-right right-left
I can't tell from the picture, but does that front rotor have a crack in it?
Post by SILINC3R »
no its probably just the rust you see. if you look you can see an outline from a brake pad
Here's the spot I was specifically referring to.
Post by SILINC3R »
yea thats just rust. he had they were sitting for sometime before i got them. thanks though
Re: Tony's 90 Leg LS
Post by SILINC3R »
Parts to be installed:
Prodrive muffler, need rest of exhaust
Parts left to buy:
2.2L headers- bought magnaflow direct fitment
coilovers
Things left to do:
find another body(L model) switch everything over
paint job
redo the interior for the 3rd time working on
redo the dash for a 2nd time done
shifter linkage(WRX) shifter
Gotta love working on cars in parking lots..... I had a caliper fail on me at a convenience store. Owner got pissed off at me so i left a huge puddle of brake fluid.
Post by SILINC3R »
thats my old college parking lot, nobody used to park there
either way, it's a good flat surface to work on.
Post by SILINC3R »
Last week installed 06 WRX springs front and rear. Good improvement over stock springs and a bit lower too.
Also installed RS front seats. Deciding if I want to install the rears as well, lighter but dont fold down.
Re: Tony's 90 Leg LS *Project N/A*
where did you get that throttle spacer?
Post by SILINC3R »
got it from REASON off his website 4Zero1Motorsports
I guess it's under construction
Post by SILINC3R »
Black vinyl dash in the works and gauge relocation
Post by SILINC3R »
so what i've learned is that dash reviynling is harder than i thought but kind of fun. i always make things more complex than they need to be. i will just buy a black dash when someone sells one.
please leave your coments and i will be posting more pictures when i get everything put back together.
Post by SILINC3R »
Did the red led mod for the instrument cluster, easy and looks good.
soobrdad02
Post by soobrdad02 »
Love the gauge relocation, looks great!
