Iam thinking of getting a 1986 Subaru XT Turbo and
am interested in learning about the reliablitity of the
engines. Any idea's? Also, Could I swap motors and
put in a bigger powerplant from a Legacy? Thanks
Anyone familiar to mid 80's XT turbo's?
thehookeup
I dont know much about those older turbos, but i do know that if the turbo in that thing hasn't blown yet, its close.
here is a link to a company that makes adapter plates for a EA motor to a newer style EJ motor. Other than wiring this is the biggest thing you would need.
http://offroadingsubarus.com/ej22swap_f ... ngine.html
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
Andrew
The early motors are not usually as stout as EJ series motors. The heads are known to crack occasionally, but never having owned one, I can't say exactly how common of a problem it was.
An EJ series motor will swap in fairly easily. There are a few write-ups on the Ultimate Subaru BBS on EA to EJ swaps.
If you can source XT6 hubs and knuckles (5-lugs and newer brakes compatable), you can do pretty much a complete WRX swap.
Caboobaroo
The EA82Ts have major headgasket issues and if overheated, will crack the water passage that runs through the head, into the exhaust port.
I'm currently swapping an EJ22T into my '87 RX for A) reliability and B) more upgradable parts. I would also recommend doing the 5-lug conversion as well. I have the XT6 rear hubs and brakes on the car, XT6 front lower control arms but I'm also using '96 Impreza front knuckles, brakes, axles and this also gave me an option for upgradable suspension as well. Check out www.ultimatesubaru.org and start browsing around there. you'll find most, if not all the info you need for these types of conversions.
1987 RX STi - EJ22T/EJ20K/EJ257
Caboobaroo
kingbobdole
